Before you drop a layer, you can apply any of the effects available in the Text panel. You can stretch, rotate, and skew text. You can apply a shadow to your text and adjust shadow attributes.
You can change the composite method for text or the shadow of a selected text layer by making a choice from the pop-up menu in the Text panel. You can specify whether you’re modifying the composite method for the text body or the drop shadow. Refer to Blending Layers by Using Composite Methods for more information about changing the composite method.
Stretching text affects both the horizontal and vertical size. As you stretch vertically, the text appears thinner and taller. As you stretch horizontally, the text appears flatter and shorter.
Rotating pivots the text from the end point of the text block. Depending on the alignment of the text, it pivots from the lower-left corner, lower-right corner, or center. You can also skew the text by slanting the text to the right or left.
Rotated text (right).
| To stretch, rotate, or skew text |
1 |
Select text using the Layer Adjuster tool |
2 |
Choose a task from the following table:
If the bounding box is not shown, click the Layers panel menu arrow and
choose Show Layer Indicators.
You can apply a shadow to text. You can also select an external shadow, which places the shadow behind the text, or an internal shadow, which places the shadow inside the text.
| To add a shadow |
1 |
Choose the Text tool |
2 |
In the Layers panel, select a text layer.
3 |
On the property bar, enable one of the following buttons:
External Shadow |
Internal Shadow |
No Shadow |
You can also add a shadow by choosing one of the shadow buttons in the Text
panel.
| To move the shadow |
1 |
In the toolbox, click the Zoom tool |
2 |
Click the text in the document window to zoom in on the text.
3 |
In the toolbox, click the Layer Adjuster tool |
Opacity controls the transparency of text or shadows. Your text’s shadow should be semitransparent. You can also use opacity to fade the color of text.
| To adjust opacity |
1 |
In the Text panel, click one of the following buttons:
Shadow Attributes |
Text Attributes |
2 |
In the Text panel, move the Opacity slider |
You can add either a focus blur or a directional blur to text and shadows. Focus blurs make text fuzzy. You can use the focus blur to soften the edges of text characters. With directional blurs, you can specify the direction in which the blur occurs.
| To add a blur |
1 |
In the Layers panel, select the Text layer or the Shadow layer.
2 |
In the Text panel, click either the Text Attributes |
3 |
Adjust the Blur slider |
If you want to apply a directional blur, enable the Directional check box, and adjust the Directional Blur slider |
The first half of the slider adds a left-to-right blur on the text; the second half adds an up-and-down blur. |
You can define a curve style and path (baseline) along which your text will flow. The baseline created by a curve style is a Bézier curve, meaning that the shape can be controlled by using control handles and anchor points. Refer to Working with Bézier Lines for more information on working with anchor points and control handles.
There are four curve styles to choose from:
You can control how the text is centered on the line. You can move the center point by dragging on the slider or by changing the alignment. Dragging the Centering slider also changes where the text starts and stops on a line. The Centering slider has no effect on the Curve Flat style. After you apply a curve style, you can change the curve of the path.
| To set a curve style and change centering |
1 |
2 |
3 |
In the Text panel, click a Curve Style icon:
Curve Flat |
Curve Ribbon |
Curve Perpendicular |
Curve Stretch |
4 |
Drag the Centering slider |
The text moves along the curve. |
You can also change the alignment of text on a path by clicking a text layer in
the Layers panel and clicking an alignment button in the Text panel. For more
information about aligning text, see To align text.
| To change the path |
1 |
Choose Window menu |
2 |
3 |
Choose the Shape Selection tool |
4 |
Click an end point on the path.
Drag the handles to change the shape of the path. |
