Image Hose
The Image Hose is a milestone in the evolution of art tools. Instead of painting with color, the Image Hose paints with images — not just one or two at a stroke, but a variety of changing images.
The images flowing from the hose change as you make a brushstroke. The Image Hose lets you control the image output. For example, by increasing stylus pressure, you can paint larger or more colorful images. By changing the direction of the stroke, you can change the angle of the images. This is just a sample of the possible controls. By creating your own set of images, you can paint with a unique image series.
The Image Hose feature allows you to paint with images.
The Image Hose deposits 24-bit images with an 8-bit mask. The mask enables you to layer the images gently, without aliased edges or artifacts.
You can load the Image Hose with images of any description — leaves, bark, grass, stones, people, or whatever you want. When you paint with these image elements, you can build them into coherent shapes, such as a tree, hill, cobblestone street, or crowd of people.
This section contains the following topics:
