Quick Clone Preferences
The Quick Clone preferences let you customize the Quick Clone behavior. For example, you can choose to always use the last selected cloner brush variant or automatically open the Clone Source panel. For more information, see Using Quick Clone.
Description
Close source image
Closes the clone source image automatically when the image is cloned. The clone source is embedded in the clone document, but the original image is closed.
Open Clone Source panel
Displays the Clone Source panel automatically when Quick Clone is used.
Clear Canvas
Lets you start cloning with a blank canvas
Turn on tracing paper
Activates tracing paper
Switch to cloner brushes
Activates the last Cloner brush variant
Clone color
Uses the current brush variant to clone the underlying color
To enable the Clone Color check box, you must disable the Switch to Cloner Brushes check box.
To change Quick Clone preferences Back to Top
Do one of the following:
(Mac OS) Choose Corel Painter 12 Preferences Quick Clone.
(Windows) Choose Edit Preferences Quick Clone.
