Transforming Selections
Path-based selections support many transformations that pixel-based selections do not. However, you can convert a pixel-based selection to a path-based selection to apply transformations to it. When you convert a pixel-based selection, the protection of the modified selection is reduced to two levels.
To determine whether a selection is pixel- or path-based, you can use the Selection Adjuster tool. If the selection displays handles when the Selection Adjuster tool is active, the selection is path-based. If the selection does not have handles, it is pixel-based. For more information about selection types, see Creating and Saving Selections.
Setting the Reference Point for Transformations
When performing a transformation on a selection, you can choose the reference point for the transformation. The reference point is located at the center of the selection by default. However, you can move the reference point. The transformation is performed around this point.
To set the reference point for a transformation Back to Top
For a selection made by using the Selection Adjuster tool , choose the Transform tool from the toolbox.
If the Transform tool is not displayed in the toolbox, click and hold the Layer Adjuster tool to open the flyout, and then choose the Transform tool.
Point to the center of the selection’s bounding box.
Drag the Reference Point to new location on the canvas.
You can place the Reference Point outside the selection.
You can reset the Reference Point to its default location by clicking the Reset Reference Point button on the property bar or choosing the Edit Transform Reset Reference Point.
Moving Selections
You can move both path-based and pixel-based selections to a new location on the canvas.
To move a selection Back to Top
On the property bar, click the Move button .
While staying within the bounding box, click the selection, and then drag it to a new position on the canvas.
4
On the property bar, click the Commit Transformation button .
If you prefer, you can apply the transformation by pressing Enter.
You can move a pixel-based selection with the Transform tool; however, if a portion of the selection moves off the canvas, it is subtracted from the selection.
To reposition a selection, use the Move tool, and drag the selection to a new position. A rectangular marquee appears while you are dragging the selection.
Transforming a Duplicate
You can transform a copy of a selection or the contents of an active layer.
To transform a duplicate Back to Top
Hold down Option (Mac) or Alt (Windows), and choose the Transform tool from the toolbox.
On the property bar, click a transformation mode.
The transformation is applied to copied content.
You can also transform a duplicate by clicking Command + Shift + Option + T (Mac) or CTRL + Shift + Alt + T (Windows).
Scaling and Rotating Path-Based Selections
You can scale or rotate path-based selections. Scaling lets you change the dimensions of a selection. You can also scale an object proportionally by preserving its aspect ratio.
To scale a selection Back to Top
In the toolbox, click the Transform tool .
If the Transform tool is not displayed in the toolbox, click and hold the Layer Adjuster tool to open the flyout, then select the Transform tool.
On the property bar, click the Scale mode button .
Perform a task from the following table.
To
Do the following
Scale a selection in one dimension
Drag a side, top, or bottom handle. On the property bar, click the Commit Transformation button .
Scale a selection in two dimensions
Drag a corner handle. On the property bar, click the Commit Transformation button .
Scale while maintaining the selection’s shape, or “aspect ratio”
Hold down Shift while you drag a corner handle. On the property bar, click the Commit Transformation button .
Scale around the reference point while maintaining the selection’s shape, or “aspect ratio”
Hold down Alt + Shift (Windows) or Option + Shift (Mac), and drag a corner handle. On the property bar, click the Commit Transformation button .
Hold down Alt (Windows) or Option (Mac), and drag a corner handle. On the property bar, click the Commit Transformation button .
Drag a side handle to scale horizontally.
You can also scale a selection by choosing Edit Transform Scale, and specifying the horizontal and vertical scale percentages in the dialog box.
To rotate a selection Back to Top
On the property bar, click the Rotate button .
Move the pointer outside the border of the selection’s bounding box.
4
If you want to constrain the rotation by 15-degree increments, hold down Shift while dragging.
5
You can also Rotate a selection by choosing Edit Transform Rotate, and specifying the rotation angle in degrees in the dialog box. A positive number rotates clockwise; a negative number rotates counterclockwise.
Rotating a selection.
Skewing and Distorting Path-Based Selections
You can skew and distort path-based selections. Skewing slants the vertical and horizontal dimensions of a selection non-proportionally. Distorting a selection lets you move the sides or corners of a selection in different directions. For example, you can crush or stretch the selection. In addition, you can use perspective distortion to give an object the appearance of depth. Skewing distortion allows you to achieve a 3D look.
To skew a selection Back to Top
On the property bar, click the Skew button .
4
Drag a side handle.
If you want to skew only the selected side, hold down Alt (Windows) or Option (Mac) while dragging the side handle.
5
Skewing a selection.
To distort a selection Back to Top
On the property bar, click the Distort button .
If you want to constrain the distortion to the horizontal or vertical axis, hold down Shift while dragging a corner handle.
If you want to distort the selection relative to the Reference Point, hold down Alt (Windows) or Option (Mac) while dragging a corner handle.
4
A selection before (left) and after (right) distorting.
To distort perspective in a selection Back to Top
On the property bar, click the Perspective Distortion button .
4
A selection before (left) and after (right) perspective distorting.
Canceling Transformations
If you are not satisfied with the transformation, you can cancel it and return the selection to its previous state.
To cancel a transformation Back to Top
Click the Cancel Transformation button on the property bar, or press Esc.
