Cropping removes unwanted areas of a bitmap. To crop a bitmap into a rectangular shape, you can use the Crop tool. For more information, see To crop objects. To crop a bitmap into an irregular shape, you can use the Shape tool and the Crop bitmap command.
| To crop a bitmap |
1 |
In the toolbox, click the Shape tool |
2 |
Select a bitmap.
3 |
Drag the corner nodes to reshape the bitmap.
If you want to add a node, double-click the node boundary (dotted line) by using the Shape tool where you want the node to appear. |
4 |
Click Bitmaps |
You can also quickly crop a bitmap into a rectangular shape by using the Crop
tool |
You can also crop a selected bitmap after you drag the corner nodes by clicking
the Pick tool |
