Add, remove, and join nodes
When you add nodes, you increase the number of segments and, therefore, the amount of control you have over the shape of the object. You can delete selected nodes to simplify an object’s shape.
When curve objects contain many nodes, it is difficult to edit and output them to devices such as vinyl cutters, plotters, and rotary engravers. You can have the number of nodes in a curve object reduced automatically. Reducing the number of nodes removes overlapping nodes and can smooth a curve object. This feature is especially useful for reducing the number of nodes in objects imported from other applications.
To add or delete a node
In the toolbox, click the Shape tool  , select a curve object, and double-click where you want to add a node.
In the toolbox, click the Shape tool, select a curve object, and double-click a node.
To reduce the number of nodes in a curve object
Shape tool
Click a curve object, and do one of the following:
To reduce the number of nodes in the entire object, click the
Select all nodes button
on the property bar.
To reduce the number of nodes in a part of a curve object, marquee select the part you want to change.
Do one of the following:
Click
Reduce nodes on the property bar to have overlapping and redundant nodes automatically removed.
Move the
Curve smoothness slider to control the number of nodes that are removed. Removing many nodes can reshape the curve object.
To join the end nodes of a single subpath
Shape tool
Click the
Close curve button
You can close multiple subpaths in an object by clicking Object
Join curves and choosing settings in the Join curves docker. For more information, see Join curves.
To join the nodes of multiple subpaths
Shape tool
Click the
Extend curve to close button
If you want to join nodes from separate curve objects, you must first combine them into a single curve object, and then join the end nodes of the new subpaths. For information about combining objects, see Combine objects.
