Callouts
Callouts are shapes or lines with text that point to and identify objects in a drawing. There are two types of callouts: callouts without leader lines and callouts with leader lines. Callouts with leader lines can have one, two, or three line segments, or "legs," between the line end and the text. You can choose from a variety of line ends, including arrowheads and other styles.
Left to right: 1-leg callout, 2-leg callout, 3-leg callout, and a callout without a leader line.
You can use different shapes for the callout text within a drawing.
Callout shape
Example
None
Box
Line (side bar)
Box and line
Circle
Square
Circle and square
Triangle
You can enhance callouts in several ways. For instance, you can change the line width and color, and you can adjust the gap between the line and the text.
Callout text
The default option for callout text lets you type text after drawing the callout. You can also insert text from the Clipboard or from object properties, or you can add a value and increase it in increments as you add more callouts. For more information about object properties, see Manage object data and track projects.
When you resize the leader line, by default the callout text is automatically resized as well. However, you can choose to scale the leader line independently of the callout text.
Left: Original graphic. Middle: The callout text is resized together with the leader line. Right: The callout text remains the same size when the leader line is resized.
Linked callouts
You can link a callout to its source object by snapping the callout arrowhead to a snap point. Linked callouts, also known as "sticky callouts," are attached to the source objects similarly to connector lines. When you move the source object, the linked callout moves with it. You can specify how linked callouts move with the object. One option is to adjust the length of the leader line, leaving the callout text in place. The other option is to move both the leader line and callout text, preserving the appearance of the callout group. You can break the link between a callout and its source object at any time.
Halos
You can also add a halo behind the callout. A halo is a mask behind the leader line and text that makes the callout easier to see when it is on top of another object. Usually, the halo is the same color as the page, although you can choose any color you like. In addition, you can lock the width ratio between the halo and the callout. This feature automatically adjusts the width of the halo when you change the callout width, and vice versa. For information about how to add a halo to a callout, see To add a halo to a line or an outline.
White halos are applied to the callouts to make them stand out against the underlying objects.
Break callouts apart
Callouts are added as linked groups. You can break the callout apart if necessary.
Default properties and hotspots
You can change the default properties of callouts, such as callout style, callout gap, and halo justification, from the Object styles docker (Window Object styles). For more information, see To edit default object properties.
For information about adding hotspots to callouts, see Add hotspots to callouts.
To draw a callout
Back to Top
1 Click one of the following tools:
• 1-Leg Callout
• 2-Leg Callout
• 3-Leg Callout
2 Click where you want to place the arrowhead and drag to where you want to end the first line segment (leg).
For 2-leg callouts, click again to end the second leg. For 3-leg callouts, click one more time to end the third leg.
3 Add the callout text.
To edit a callout that has a leader line
Back to Top
1 Using the Pick tool , select the callout.
2 Perform a task from the following table, using the corresponding control on the property bar.
To
Do the following
Change the width of the leader line
Type a value in the Outline width box.
Change the callout start endpoint
Choose a style from the Start arrowhead list box.
Change the line style
Choose a style from the Line style list box.
Change the callout shape
Choose a shape from the Callout shape list box.
To change the size of the callout shape, type a value in the End size box. This control is not available for all callout shapes.
Change the distance between the leader line and the callout text
Type a value in the Gap box on the property bar.
Left: Object with a callout. Right: The following callout properties were changed: start endpoint, line width, line color, and callout shape.
To place a callout that has no leader line
Back to Top
1 Click the Callout tool, and click where you want to place the callout shape.
2 Add the callout text.
You can also
Using the Pick tool , click the callout, and choose a shape from the Callout shape list box on the property bar.
Change the size of the callout shape
Using the Pick tool , click the callout, and type a value in the End size box on the property bar.
Callouts without leader lines
To place a linked callout that has no leader line
Back to Top
1 Click the Callout tool.
2 Click the Link callout button on the property bar, and choose one of the following options:
• Keep Callout Position — lets you leave the callout text and shape in place when you move the object, and adjust the callout position if needed
• Move Linked Callout — lets you move the callout shape and text with the object
3 Point to where you want to place the callout shape on the object, and click when a gravity source (snap point) appears.
4 Add the callout text.
To choose an option for callout text
Back to Top
1 Click a callout tool, and click the Text source button on the property bar.
2 Enable one of the following options:
• Interactive — lets you type the text at the end of the callout line
• Clipboard — pastes text from the Clipboard to the callout
• Object data — adds an object property that you choose, such as the object name, to the callout. For more information, see To draw a callout that shows object properties.
• Increment — adds a numeric value to the callout. The value is increased in increments as you continue to add callouts, and you can specify the start value and the increment amount. The increment values that you set apply only to the active drawing.
Back to Top
1 Click a callout tool in the toolbox, and click the Text source button on the property bar.
2 Enable the Object data option.
3 Using the callout tool, draw a callout, snapping the start end to a gravity point in the object.
4 In the Callout Data dialog box, enable the check boxes for the object properties you want to display in the callout text.
5 Enable any of the following check boxes:
• Include field name — includes the field name (such as name or cost) in the callout text
• Keep updated — automatically updates the callout text when the object data is modified. This option is available only for linked callouts.
• Apply as default — sets the current settings in the dialog box as the defaults for new callouts. The Callout Data dialog box will not be shown when you add other callouts that include object data.
You can change how object data is displayed in a callout by clicking the Callout object data button on the property bar and modifying the settings you want in the Callout Data dialog box.
If properties are associated with an object, you can show them in callouts.
To scale the leader line independently of the callout text
Back to Top
1 Using the Pick tool, select a callout.
2 Click Tools Options Tools.
3 In the Options dialog box, click Callouts.
4 Disable the Scale text with leader line check box, and click OK.
5 Use the selection handles to resize the callout.
This option is applied to all new callouts you create.
To draw a linked callout
Back to Top
1 Click one of the following callout tools in the toolbox:
• 1-leg callout
• 2-leg callout
• 3-leg callout
• Keep Callout Position — lets you adjust the length of the leader line, leaving the callout text in place
• Move Linked Callout — lets you move both the leader line and callout text with the object
3 Point to where you want to place the arrowhead on the object, click when a gravity source (snap point) appears, and drag to where you want to end the first line segment.
4 Click to end each line segment.
5 Add the callout text.
Links between callouts and objects are not maintained when a drawing is saved to Corel DESIGNER X5 or earlier version.
For information about linked callouts without leader lines, see To place a linked callout that has no leader line.
To break the link between the callout and the object, click the Link callout button on the property bar, and choose Break Callout Link. You can also right-click the callout and choose Break Callout Link from the context menu.
To break a callout apart
Back to Top
• Right-click the callout, and click Break callout apart.
The objects in the callout are ungrouped and can be edited individually.
