Export objects and pages
Corel DESIGNER lets you manage and export assets using the Export docker. You can export one or more objects and pages, or a group of objects to the PDF, JPEG, PNG, SVG, EPS, TIFF, GIF, BMP, CGM, PSD, WEBP, CDR, AI, DWG, and DXF formats.
To export an object, you must select it in the document and add it to the Export docker. You can add the active page to the export list You can also select multiple objects or pages and add them to the export list with a single click; each asset will appear as a separate entry in the list. For more information about selecting objects, see Select objects. For information on selecting pages, see Select and activate pages.
You can remove a selected item from the export list, and you can select all items in the list and remove them at once.
By default, when you add an asset for export, the filename that appears in the export list is the same as the name of the object in the Objects docker (Window Objects). To change the filename of an export item, you can rename it in the Export docker. You can also add a suffix to the filename to make it more meaningful and descriptive. For example, if you are exporting the same design asset to different sizes, you can add a suffix to indicate the size.
You can export an asset multiple times with different settings. Corel DESIGNER also lets you reuse export settings. For example, to export the pages needed for an interactive parts catalog to SVG using the same settings, add the first page to the Export docker and set it to be exported to SVG that uses object data for interactive effects. You can then select the other pages and add them to the export list by using the same SVG settings.
In the Export docker, pages are listed first and are arranged in the order in which they appear in the document regardless of the sequence in which you add them for export. All objects are listed next in the order in which they appear in the Objects docker. For example, in a multipage document, objects on page 1 will be listed before objects on page 5.
To manage export assets
Back to Top
• Perform a task from the following table.
To
Do the following
Add an object to the export list
Select an object in the document window, and click File Export docker Add selection.
Add the active page to the export list
Click File Export docker Add current page.
Add multiple assets to the export list
Select multiple assets in the document window, and click File Export docker Add selection.
Each asset is added as a separate item to the export list.
Add all pages to the export list
Click File Export docker Add all pages.
You can separate the pages into unique export list items by clicking the Options button beside the entry and clicking Separate pages.
Add specific pages to the export list
Click File Export docker Add all pages. Click the Options button beside the entry, and enter specific pages, page ranges or both, separated by commas in the Pages box.
Remove an item from the export list
Click the Delete button beside the item you want to remove from the list.
Remove all items from the export list
Click the Select all button , and then click the Delete button at the bottom of the Export docker.
Duplicate an item in the export list
Click the Options button beside the item you want to duplicate, and click Duplicate.
Add an asset by reusing the settings of an item in the export list
In the document, select an asset. In the Export docker, click the Options button beside the entry whose settings you want to copy, and click Add asset with these settings.
Rename an asset
Click the name label, and enter a new name.
You can also open the Export docker by clicking Window Export.
You can also add items to the export list by clicking the Add button at the bottom of the Export docker, and choosing an option.
To export an asset
Back to Top
1 Add an asset to the export list of the Export docker.
2 Choose a file format from the File format list box.
If you want to make the filename more descriptive and meaningful, enter a suffix.
3 Click the Destination folder button , and browse to the drive and folder where you want to save the file.
4 Click the Options button , and click Export Item.
You can also
Export multiple items
In the Export docker, enable the Select Item check boxes beside the items that you want to export. Click Export.
Tip: To export all items in the list, click the Select all button , and then click Export.
Modify export settings
In the Export docker, click the Settings button , and specify the options you want.
Outline width and position impact object dimensions during export to bitmap formats. If the outline is centered on, or is outside of, the object’s edge, the exported object will have larger dimensions than those displayed in the Object size boxes on the property bar when the object is selected. To keep the exported object the same size as the one in your drawing, choose the Inside outline option in the Position area of the Properties docker. For more information, see To specify line and outline settings. Objects not aligned to an even number of pixels or text extending beyond its bounding box will also increase the dimensions on export to ensure all selected pixels in a document are exported.
The Export button is grayed out when there are no items selected.
To export linked groups, such as contours, blends, extrusions, shadows, and objects created with the Artistic media tool , first group the objects in the linked group, and then add the group to the Export docker. For example, if you want to export an object with an inner shadow, create a group from the object and the shadow, and then add the group to the Export docker.
You can also duplicate a page and export it to a new document. For more information, see To duplicate and export a page to a new document.
To choose the default file format for new items
Back to Top
• From the Default file format list box at the bottom of the Export docker, choose a default file format.
