Styles and style sets
Corel DESIGNER provides advanced style capabilities that allow you to format your documents with speed, ease, and consistency. You can create and apply styles and style sets to different types of objects: graphic objects, artistic and paragraph text, callout and dimension objects, and any objects created with the Artistic Media tools.
Styles and style sets are groups of attributes that determine the appearance of objects. When you apply a style or style set to an object, all the attributes defined in that style are applied to the object in one step. That is how you can format simultaneously many different objects and significantly reduce your set-up and production time. What is more, when you edit a style or style set, all the objects defined by that style are automatically updated.
You can also export styles and style sets as style sheets for use in other documents, or import them from previously saved style sheets.
You can quickly change the look of an object by applying a style set.
This section includes the following topics:
• Create styles and style sets
• Apply styles and style sets
• Edit styles and style sets
• Manage and apply default object properties
• Export and import style sheets
• Assign keyboard shortcuts to styles or style sets
• Find objects that use a specific style or style set
• Break the link between objects and styles or style sets
