A style is a set of formatting attributes. When you apply a style to an object, all the attributes of the style are applied to that object in one step. Styles can save you considerable time if you must apply the same formatting to several objects.
There are graphics styles and text styles. A graphics style consists of fill and outline settings that you can apply to graphics objects such as rectangles, ellipses, and curves. For example, if you have a group of objects in a drawing that use one graphics style, you can simultaneously change their fill by editing the graphics style. For more information on applying fills, see Filling objects. For more information about changing the appearance of outlines, see Formatting lines and outlines.
A text style is a set of text settings such as font type and size. Text styles can also include fill and outline attributes. For example, you can create a style that applies a 72 point AvantGarde font with a texture fill. There are two types of text styles: artistic and paragraph. You can also change the properties of default artistic and paragraph text. For example, you can change the properties of default artistic text, so that every artistic text object you create has the same formatting. For information about default text, see Changing the basic properties of text.
You can create a graphics or text style from the properties of an existing object or from scratch, at which time the style is saved. When you apply a style to an object, the program overrides the existing text or graphics properties with the properties of the current style. To use the style in another drawing, you can copy the style to the new drawing or save the style in a template. For more information about templates, see Working with templates. If you copy or import a style with the same name as an existing style, the program renames the style by adding a number to the style name. At any point, you can rename a style, unless it is a default style. You can also change the properties of an object back to its previous style if you made a mistake or decide that the previous style was better suited to that object.
After you create a style, you can edit its properties and find any object using a given style. For example, you can find all objects that use the default graphics style. Finding objects assigned a specific style makes editing that style even more efficient.
You can also make any custom graphics or text style the default style for new objects.
| To create a graphics or text style from an object |
1 |
Right-click an object whose style properties you want to save.
2 |
Click Styles |
3 |
Enable one or more of the following check boxes:
Text
Fill
Outline
4 |
In the Save style as dialog box, type a name for the style in the Name box.
When you create a style from an existing object, CorelDRAW does not
automatically apply the style to an object. If you want an object to use the style,
you must apply the style. For information about applying a style, see To apply
a graphics or text style.
You can also create a graphics or text style from an object by dragging the
object to the Graphic and text styles docker.
| To create or edit a graphics or text style |
1 |
Click Tools |
2 |
In the Graphic and text styles docker, click the flyout button |
3 |
Click New, and click one of the following style types:
Graphic style
Artistic text style
Paragraph text style
4 |
Choose a style from the list.
5 |
Click the flyout button, and click Properties.
6 |
Click Edit beside a property.
7 |
Modify any text, fill, or outline properties.
| To apply a graphics or text style |
1 |
Select an object.
2 |
Click Tools |
3 |
In the Graphic and text styles docker, double-click a style.
| To find objects assigned a specific graphics or text style |
1 |
Click Tools |
2 |
Choose a style from the list in the Graphic and text styles docker.
3 |
Click the flyout button |
