You can change the appearance of objects in the drawing window by using the following transformations.
You can transform an object interactively by using the mouse and the Pick tool. This method is the quickest, but it is not recommended if you want to transform an object with precision.
You can transform an object in any of the following ways:
For more precise results, you can select an object with the Pick tool and adjust
settings on the property bar. For example, you can specify a precise rotation angle
or specify the size of an object.
The Transformation docker lets you transform objects with precision and apply
the transformation to the duplicate of an object, which is created automatically.
This feature lets you experiment with transformations without affecting the
original object. You can access the Transformation docker by clicking Arrange |
The Transform toolbar also lets you transform objects with precision. You can
access the Transform toolbar by clicking Windows |
Each of these methods lets you apply transformations to a single object or to multiple objects simultaneously.
All transformations can be simultaneously cleared at any time.
| To transform an object interactively |
1. |
Select an object by using the Pick tool.
The bounding box of the object appears. The bounding box includes eight selection handles that you can use to size, stretch, and mirror the object. If you click the object again, new handles appear. You can use these handles to rotate and skew the object.
Handle types: selection (1), rotation (2), and skew (3)
2. |
Perform a task from the following table.
If you want to leave the original object unchanged and apply the
transformation to copies that are created, type a number in the Copies box in
the Transformation docker.
| To clear all transformations applied to an object |
1. |
Select an object.
2. |
Click Arrange |
You can undo the Clear transformations command by clicking Edit |
