Objects
Working with objects is an essential part of creating drawings.
This section contains the following topics:
Select objects
Edit objects in Focus mode
Transform objects
Copy, duplicate, and delete objects
Create objects from enclosed areas
Create a boundary around objects
Feather object edges
Use object coordinates to draw and modify objects
Copy object properties, transformations, and effects
Clone objects
Position objects
Align and distribute objects
Apply object hinting
Snap objects
Dynamic guides
Alignment guides
Change the order of objects
Size and scale objects
Rotate and mirror objects
Modify objects with the Properties docker
Fit objects to a path
Group objects
Combine objects
Lock objects
Find and replace objects
Hide and show objects
Constrain objects
Export objects
Bar codes
