You can add colored, patterned, textured, and other fills to the inside of objects. You can customize a fill and set it as a default, so that each object you draw has the same fill.
This section contains the following topics:
• | Uniform fills |
• | Fountain fills |
• | Hatch fills |
• | Vector and bitmap pattern fills |
• | Two-color pattern fills |
• | Texture fills |
• | PostScript fills |
• | Mesh fills |
• | Apply fills to areas |
• | Work with fills |
