Reference: Working with symbols
Modifying symbol instances
Unsupported object types
This reference section contains additional information about working with symbols.
Modifying symbol instances Back to Top
The following object properties can be modified for symbol instances. If a symbol contains multiple objects, all objects in the symbol instance are treated collectively as a single object, just as if they were grouped.
Type values in the Object position boxes on the Transform toolbar. For more information, see Move objects.
Type width and height values in the Object size boxes on the Transform toolbar. For more information, see Size and scale objects.
Type a value in the Angle of rotation box on the Transform toolbar. For more information, see Rotate objects.
Uniform transparency only. In the Symbol area of the Properties docker, move the Transparency slider. For more information, see Object transparency.
In the Summary area in the Properties docker, choose an option from the Wrap paragraph text list box. See Wrap text.
The name of an instance is displayed in the Objects docker. Click twice to change it.
Unsupported object types Back to Top
Most objects in Corel DESIGNER can be converted to symbols, with the following exceptions.
