You can import text in a new or existing document. This allows you to author text in a word processor and then add it to a Corel DESIGNER document. Corel DESIGNER supports the following text file formats:
ANSI Text (TXT)
Microsoft Word Document (DOC) files
Microsoft Word Open XML Document (DOCX) files
WordPerfect file (WPD)
Rich Text Format (RTF) files
When importing or pasting text, you can choose to keep or discard fonts and formatting. Maintaining fonts ensures that imported or pasted text retains its original font. Maintaining formatting preserves information such as bullets and columns. If you choose to discard fonts and formatting, the properties of the selected text are applied to the imported or pasted text. If no text is selected, the default font and formatting properties are applied to the imported or pasted text. For more information about importing files, see Importing files. For more information about pasting, see To paste an object into a drawing.
The text import cursor lets you place text on the drawing page.
You can import text in a selected text frame, or, if you did not select a text frame, the imported text is automatically inserted in a new text frame in the document window. By default, the size of text frames remains static, regardless of how much text you add to them. Any text that does not fit the frame is hidden and the frame appears red until you enlarge it or link it to another text frame. You can adjust the text size so that the text fits perfectly in the frame. For more information, see Combining and linking paragraph text frames.
To import text in a document |
1. |
Using the Text tool
, position the cursor in the text frame where you want to
import the text.
If you do not have a text frame in the document, skip step 1 and proceed to step 2. |
2. |
Click File Import.
3. |
Choose the drive and folder where the file is stored.
4. |
Click the filename.
5. |
Click Import.
6. |
In the Importing/Pasting text dialog box, choose one of the following options:
Maintain fonts and formatting
Maintain formatting only
Discard fonts and formatting
If you want to apply CMYK black to the imported black text, enable the Force CMYK black check box. This check box is available when you choose an option that maintains text formatting. |
7. |
Do one of the following:
Position the import cursor in the drawing page, and click.
Click and drag on the drawing page to define the size of the text frame.
Press the Spacebar to place the imported text in the default location.
For more information about importing a specific file format, see Supported file
formats.
To paste text in a document |
1. |
Copy or cut text.
2. |
Click Edit Paste.
3. |
In the Importing/Pasting text dialog box, enable one of the following options:
If you choose to maintain fonts, but the text that you import requires a font
that is not installed on your computer, the PANOSE font matching system
substitutes the font for you. For more information, see Substituting fonts.
You can also set hyphenation options for imported text. For more information
about hyphenation options, see To create a custom definition for optional
hyphenation.
If you want to use the same formatting options whenever you import or paste
text, enable the Don’t show this warning again check box. To reactivate the
warning, click Tools Options, click Warnings in the Workspace list of
categories, and enable the Pasting and importing text check box.
