Watercolor
Corel Painter features different tools and controls that allow you to produce natural-looking watercolor effects. The tools include watercolor brushes that are stored in the following brush categories.
The Real watercolor brushes allow you to apply pigment to the paper in a very realistic way. They include brush control options that allow you to precisely control water and paper interactions. The Real watercolor brushes are applied to the Watercolor layer.
The Pigment watercolor brushes are designed to produce natural-looking effects. They include brush control options that allow you to control color diffusion and some water and paper interactions. The Pigment watercolor brushes are applied to the Watercolor layer.
The Fringe watercolor brushes let you apply watercolor effects directly to the canvas or a default layer, without the need for a Watercolor Layer. However, the brush control options for Fringe watercolor are limited.
There are Watercolor-compatible brushes in other categories as well. To check whether a brush is compatible with Watercolor, look for the Watercolor Layer compatibility icon
in the bottom-right corner of the Brush selector. For more information on painting with compatible brushes on special layers, see Special layers preferences. For information about the Layer compatibility icons, see To show or hide the layer compatibility icons.
You can also alter the appearance of watercolor by changing the paper texture and modifying the brush controls.
This section contains the following topics:
