Adjusting Selections
Corel Painter lets you adjust selections in various ways. You can invert a selection, which deselects the previously selected area and selects the previously unselected area. You can also change the look of the edges of a selection by feathering, anti-aliasing, stroking, or changing the borders. In addition, you can adjust the size of selections by expanding and contracting the pixels. You can also add or subtract areas of the selection.
Inverting Selections
Inverting a selection switches the selected and unselected areas. For example, in an image of a boat on water, if you've created a precise selection of the boat, you can select everything but the boat by inverting the selection.
The flower is selected (left). After inverting the selection, everything but the flower is selected (right).
A pixel-based selection can have 256 values in it, like a grayscale image. An inverted pixel-based selection is equivalent to the negative of a grayscale image. For example, a pixel that has 80% luminance will have 20% luminance when inverted.
To invert a selection Back to Top
In the toolbox, click the Selection Adjuster tool , and then click a selection.
From the menu bar, choose Select Invert Selection.
For a unique effect, you can nudge the selection by a few pixels and choose the command again. To nudge the selection, use the Selection Adjuster tool to click the selection, and then press an arrow key on your keyboard a few times. This technique works only when the selection is directly on the canvas, it does not work if the selection is on a layer.
Softening the Edges of Selections
You can soften the edges of a path-based selection by anti-aliasing or feathering. Anti-aliasing smooths the edges of a selection by modifying the color transition between the pixels. Feathering, on the other hand, softens the edges by gradually increasing the transparency of the pixels along the edge of the selection.
To apply anti-aliasing to a selection Back to Top
Create a selection by using one of the selection tools.
On the property bar, click the Anti-Alias button .
To feather the edge of a selection Back to Top
From the menu bar, choose Select Feather.
In the Feather Selection dialog box, specify the number of pixels that you want to feather.
When the selection marquee is shown, feathering may be difficult to see. It is easier to see the effect of feathering if you save the selection to a channel and view the channel. For more information, see To view or hide a channel.
Stroking Selections
You can apply a stroke to a path-based selection. Corel Painter uses the current brush variant, brush size, color, and paper texture to apply a stroke along the border of a selection. Stroking selections is an excellent way to make brushstrokes follow specific contours.
You can set the drawing mode to control whether brushstrokes are placed inside the selection border, outside the selection border, or on both sides of the selection border. For more information, see Protecting an Area of the Canvas.
To stroke a selection Back to Top
Create a path-based selection.
In the toolbox, click the Brush tool .
Click the Brush Selector on the Brush Selector bar.
4
In the Brush Library panel, click a brush category, and click a brush variant.
5
Click a color in the Color panel.
6
On the property bar, type a value in the Size box, or adjust the pop-up slider.
7
Click the drawing mode icon in the lower-left corner of the document window, and choose a drawing mode.
8
From the menu bar, choose Select Stroke Selection, and repeat the command to build strokes.
You can use different brushes while building strokes.
Stroking a selection while using the Draw Anywhere drawing mode lets you apply strokes to both sides of the selection border.
Modifying the Borders of Selections
The Select menu has several options for modifying the borders of path-based selections. You can increase the border width. You can smooth a selection by removing sharp edges, rounding corners, and straightening the outline path.
To modify the border of a selection Back to Top
From the menu bar, choose Select Modify Border.
In the Border Selection dialog box, specify the number of pixels for the width of the border.
Border selection with airbrush strokes applied.
To smooth a selection Back to Top
From the menu bar, choose Select Modify Smooth.
Repeat the command from the previous step until the path is sufficiently smooth.
Selection before (left) and after (right) smoothing.
Expanding or Contracting Selections
You can expand or contract a selection by a set number of pixels. When you expand a selection, it is expanded on all sides by the specified number of pixels. When you contract a selection, it shrinks on all sides by the specified number of pixels.
To expand or contract a selection Back to Top
To
Do the following
Expand a selection
Choose Select Modify Widen. In the Widen Selection dialog box, specify the number of pixels.
Contract a selection
Choose Select Modify Contract. In the Contract Selection dialog box, specify the number of pixels.
Adding to or Subtracting from Selections
You can adjust the size and shape of a selection by adding or subtracting selection areas.
To add to a selection Back to Top
On the property bar, click the Add to Selection button .
Select the area that you want to add.
If you are using the Oval Selection tool or the Rectangular Selection tool , you can select a circular or square area by holding down Shift while dragging.
You can also add to a selection by holding down Shift and selecting the area that you want to add. If you are using the Oval Selection tool or the Rectangular Selection tool and you want to select a circular or square area, you need to release Shift for a moment and then hold down Shift again while dragging.
When making selections, you can use any combination of selection tools, including the Magic Wand tool . If you combine pixel- and path-based selections, the result is a pixel-based selection. For more information about creating pixel-based selections with the Magic Wand tool, see To select an area by using the Magic Wand tool.
Adding to a path-based selection.
To subtract from a selection Back to Top
On the property bar, click the Subtract from Selection button .
Select the area that you want to subtract.
If you are using the Oval Selection tool or the Rectangular Selection tool , you can select a circular or square selection by holding down Shift while dragging.
You can also subtract from a selection by holding down Option (Mac OS) or Alt (Windows) and selecting the area you want to subtract. If you are using the Oval Selection tool or the Rectangular Selection tool and you want to select a circular or square area, you need to hold down Option + Shift (Mac OS) or Alt + Shift (Windows) while dragging.
Subtracting from a path-based selection.
