Creating and Exporting Color Sets
You can create color sets to control the colors in particular projects or to create groups of favorite painting colors. Creating clearly named color sets can be very useful. For example, you could name a color set Shades of Purple, Hero Image, My Crayons, or Rollover Buttons — all offering you easy access to recognizable color sets.
You can create color sets from
an image
a selection on an image
a layer
the Mixer panel
Once a color set is created, you can add additional colors to the color set. You can also export the color set.
To create a color set Back to Top
Choose Window Color Panels Color Sets.
In the Color Set Libraries panel, click the New Color Set button , and choose one of the following options:
New Color Set from Image — Includes all image colors in the color set. This option is available only if an image is open.
New Color Set from Layer — Includes all colors that are found in the active layer in the color set. This option is available only if an active layer is selected in the image.
New Color Set from Selection — Includes all colors in the selected area of the image in the color set. This option is available only if the image has an active selection.
New Color Set from Mixer Pad — Includes all colors that are used in the Mixer panel in the color set.
Note
For information about adding colors to a color set, see Editing Color Sets.
For more information about selecting colors, see Using the Color Panel.
To export a color set Back to Top
In the Color Set Libraries panel, click the Export Color Set button .
Choose the name of the color set that you want to export from the Library list box.
Click Ok.
4
Choose the drive and folder where you want to save the file.
If you want to rename the color set, type a name for the color set in the File Name box.
5
Click Save.
