Editing Color Sets
You can customize color sets by adding, deleting, or replacing colors. You can also append colors to a color set. This is useful if you want to use colors from multiple color sets. In addition, you can name or rename individual colors in a color set.
Naming colors in a color set can be useful. You can then search for a color by name, or annotate the colors you use, right in the document window. For more information about searching for a color, see To find a color in a color set. For more information about annotating colors, see Annotating Colors.
To add a color to a color set Back to Top
In the Color panel, choose a color.
In the Color Set Libraries panel, choose the color set where you want to add the selected color.
Click the Add Color to Color Set button .
4
In the Color Set Libraries panel, click the Add Color to Color Set button .
You can also
Add a sampled color to a color set
Click the Dropper tool in the toolbox, click a color in the image, then click the Add Color to Color Set button .
Add a color from another color set
Drag a color swatch from one color set to another.
To delete a color Back to Top
In the Color Set Libraries panel, choose a color and click the Delete Color from Color Set button .
In the warning dialog box, click Yes.
Corel Painter deletes the chosen color from the color set.
To replace a color Back to Top
Choose the color you want to add from the Color panel, a color set, or an existing image.
Hold down Command (Mac OS) or Ctrl (Windows), and click the color you want to replace.
The new color replaces the old one in the color set.
To hide or display color Back to Top
Perform a task from the following table.
To
Do the following
Hide a color
Right-click a color swatch in the Color Set Libraries panel, and choose Hide Color.
Display all hidden colors
In the Color Set Libraries panel, click the Color Set Options button , choose Color Set Library View, and choose Show All Hidden Items.
To name or rename a color Back to Top
Right-click a color swatch in the Color Set Libraries panel, and choose Rename.
Type a color name in the New Name text box.
Color names can contain up to 31 characters.
To restore the default color set Back to Top
In the Color Set Libraries panel, click the Color Set Options button , choose Restore a Default Color Set.
