Filling an Area With a Sampled Image
You can apply a transformed sample by filling, instead of using a brush. Filling allows you to cover a large area evenly, without much effort. Filling is supported only when you use perspective or bilinear sampling, with or without tiling.
To apply a transformed sample as a fill, you need to set both sample source and destination reference points, as you would when applying a sample with a brush. For information, see Applying Transformations When Sampling.
If you want to save the sample source reference area as a pattern for future use, you can capture the pattern. For more information, see Creating and Editing Patterns.
To fill with a transformed source image Back to Top
Click the Brush Selector on the Brush Selector bar.
In the Brush Library panel, click the Cloners category, and click a brush variant that allows you to select four sample source and destination points:
XPerspective 4P
XPerspective Tiling 4P
XBilenear 4P
Choose Window Brush Control Panels Cloning.
4
In the Cloning panel, enable the Clone Color check box.
5
Hold down Option (Mac OS) or Alt (Windows), and click to set the four sample source reference points.
6
Hold down Option + Shift (Mac OS) or Alt + Shift (Windows), and click to set the four destination reference points.
7
Click the Paint Bucket tool from the toolbox.
8
Choose Source Image from the Fill list box on the property bar.
9
Click in the destination area to apply the fill.
You can disable offset sampling by clicking the Clone Color button in the Color panel or by clicking the Brush Selector on the Brush Selector bar, and choosing a non-Cloner brush variant.
The destination points determine where the transformation occurs.
By using transformed clone information, the brick pattern becomes a steep wall.
