Tables
A table provides a structured layout that lets you present text or images within a drawing. You can draw a table, or you can create a table from paragraph text. You can easily change the look of a table by modifying the table properties and formatting. In addition, because tables are objects, you can manipulate them in various ways. You can also import existing tables from a text file or a spreadsheet.
This section contains the following topics:
Add tables
Select, move, and navigate table components
Insert and delete table rows and columns
Resize table cells, rows, and columns
Format tables and cells
Text in tables
Convert tables to text
Merge and split tables and cells
Manipulate tables as objects
Add images, graphics, and backgrounds to tables
Import tables
