This reference section contains additional information about working with symbols.
| Modifying symbol instances |
The following object properties can be modified for symbol instances. If a symbol contains multiple objects, all objects in the symbol instance are treated collectively as a single object, just as if they were grouped.
Property
Notes
Position
Type values in the Object position boxes on the Transform toolbar. For more information, see Moving objects.
Size
Type width and height values in the Object size boxes on the Transform toolbar. For more information, see Sizing and scaling objects.
Skew
See Skewing objects.
Rotation angle
Type a value in the Angle of rotation box on the Transform toolbar. For more information, see Rotating objects.
Transparency
Uniform transparency only. In the Symbol area of the Property manager docker, move the Transparency slider. For more information, see Applying transparencies.
The transparency slider is disabled if the symbol contains an object with transparency already applied to it.
Mirroring
Wrap paragraph text
In the Summary area in the Property manager docker, choose an option from the Wrap paragraph text list box. See Wrapping text.
Order
Name
The name of an instance is displayed in the Object manager docker. Click twice to change it.
| Unsupported object types |
Most objects in Corel DESIGNER can be converted to symbols, with the following exceptions.
