There are a number of tasks that are common to all types of fills. You can choose a default fill color so that every object that you add to a drawing has the same fill. You can also remove a fill, copy it to another object, or use it to fill an area surrounded by an open curve.
| To choose a default fill color |
1. |
Click a blank area on the drawing page to deselect all objects.
2. |
Click any rectangle or circle tool.
3. |
On the property bar, click the Fill button
4. |
In the Uniform fill dialog box, specify any fill settings.
You can also change the default fill color by editing the default style sets in the
Object styles docker. For more information, see Managing default object
properties.
| To remove a fill |
1. |
Select an object.
2. |
Click Edit |
3. |
In the Property manager docker, click the No fill button
You cannot remove mesh fills by following this procedure. To remove a mesh
fill from an object, select the object by using the Mesh fill tool
| To copy a fill to another object |
1. |
Using the Pick tool
2. |
With the right mouse button, drag the object over the destination object to which
you want to apply the fill.
A blue outline of the first object follows the pointer to the destination object. |
3. |
When the pointer changes to a crosshair pointer
You can also use the Attributes eyedropper tool
You can also sample the color of an existing object and apply the sampled color
to another object as a uniform fill. For more information, see To sample a color.
| To show fills in open curves |
1. |
Click Tools |
2. |
In the list of categories, double-click Document, and click General.
3. |
Enable the Fill open curves check box.
