This topic describes what was new in earlier versions of Corel Painter.
What was new in Corel Painter 2016
| Rotatable media |
In Corel Painter 2016, you can change the angle of paper textures and flow maps to get an unprecedented variety in the look of your brushstrokes. For more information see Rotating paper texture and To customize a flow map.
Rotatable media can help you vary the look of your brushstrokes.
| Default-settings restoration |
Corel Painter 2016 makes it easier to preserve custom content when you reset the application to its factory settings. Now when you restore default settings, you can maintain custom brushes and palettes, paper textures, nozzles, scripts and more. In previous versions, retaining any customizations required exporting libraries, restoring default settings, and then importing the libraries. For more information, see Restoring the default Corel Painter settings.
| Dynamic Speckles |
This feature combines Particle System physics and brush-thickness control linked to your touch, allowing you to create luscious Natural-Media brushstrokes or progressive-looking Pollock splatters. You can use this feature with select Bristle, RealBristle and Particle brushes, so you can take full advantage of those revolutionary, Painter-exclusive technologies. For more information, see Dynamic Speckles controls.
Dynamic Speckles generate a continuous brushstroke from discrete spots of color or speckles.
| Audio Expression |
Corel Painter 2016 lets you use an audio input device, such as a microphone, or internal audio to modify the look and feel of any brush. For example, your brushstrokes may change their appearance in synch with streaming music. Audio Expression allows you to link a variety of brush controls to audio input. In addition, you can adjust the strength of an audio signal, controlling its impact on a brush. For example, if you link brush size to quiet audio, increasing the strength will result in wider brushstrokes. Conversely, if the audio is loud, decreasing the strength will result in narrower brushstrokes. In addition, you can set the range of the audio expression to achieve a wider range of brushstroke variation (for example, minimum to maximum brushstroke width) regardless of whether the audio is consistently strong, low, or varies. For more information, see Audio Expression.
| Document Views |
Whether you are working on a project, showing your work, or demonstrating a technique, Corel Painter 2016 makes it even easier to switch between document views. You can switch document views from the toolbox, the Window menu, and by using keyboard shortcuts. The Default view shows all the open documents together with commonly used application controls while the Single Document view lets you focus on the active document. The Presentation Mode hides the menu bar and the taskbar of the operating system, leaving only essential controls. For more information, see Switching document views.
Single Document View (left); Single Document View in Presentation Mode (right)
| Brush Hints |
Depending on the brush type you are currently working with, context-sensitive brush hints (Help
Hints) provide useful tips about brush technologies. It’s a great way to discover different ways you can take advantage of a variety of unique Corel Painter features, including Particles, Watercolor brushes, Liquid Ink, Cloner, Impasto, and the new Dynamic Speckles.
| Visual tooltips |
At a glance, you can see the effect of high and low setting values.
| Adobe Photoshop brush file import |
With Corel Painter 2016, you can import the brush stamps of pixel-based Adobe Photoshop brushes stored in Adobe Brush Resource (ABR) files. These files contain a collection of Adobe Photoshop brushes, including shape, texture, dynamics, and other brush information. All other brush attributes specified in the ABR files are not imported, but can be fully customized in Corel Painter. For more information, see Importing Photoshop brush images.
Each imported brush stamp appears as a new brush variant.
| Custom content sharing |
You can share content saved to a custom palette.
| Welcome Screen |
| Special media brushes |
| Layer blending |
Whether you are painting with a single color or blending two or more colors on a layer, the Enhanced Layer Blending option can help you produce brushstrokes without white fringes. For more information, see Blending controls.
Brushstrokes without (left) and with Enhanced Layer Blending (right)
What was new in Corel Painter 2015?
Real-Time Stylus and Windows Tablet PC support let you create art on the go.
What was new in Corel Painter X3?
Changes to the brush control panels
For more information about the brush control panels that include the new Jitter controls, see Controlling the behavior of Jitter variants.
