Scaling and transforming photos using the Pick tool
The Pick tool lets you transform images interactively in the following ways:
Scaling resizes an image horizontally, vertically, or proportionally.
Shearing skews an image vertically or horizontally.
Distorting an image stretches or contracts it in any direction.
Applying perspective to an image corrects the perspective or
applies a false perspective. For information about correcting
image perspective, see Correcting photographic perspective.
Rotating an image moves it around a pivot point. For information
about rotating images, see Rotating images.
When you transform an image, the transformations are applied to the layer on which the image resides. You can apply transformations to any raster layer or selection.
Setting scaling and transformation options
You can precisely control many of the deform settings. The following options appear on the Tool Options palette when the Pick tool is active:
Pivot X, Pivot Y — sets the X and Y coordinates of the rotation
pivot point
Position X, Position Y — sets the X and Y coordinates of the top
left corner handle
Scale X (%), Scale Y (%) — sets the percentage of change for the
horizontal (X) and vertical (Y) resizing
Shear — sets the offset of a side. Positive values shear to the right,
and negative values shear to the left.
Angle — sets the rotation around the pivot point. The image is
rotated clockwise, from 0 to 360 degrees.
Reset button |
Perspective X, Perspective Y — adjusts the perspective of the
deformation
The best way to create and adjust perspective is by dragging the control handles. When you create a perspective effect with the control handles, you manipulate many variables. Changing the values in the Perspective X and Perspective Y controls may affect the scale, shear, and position values. |
Important! The Pick tool works on grayscale and 16 million– color
images only. For more information about increasing the color
depth of an image, see Increasing the color depth of an image. For
more information about deforming vector objects or text, see
Sizing, shaping, and rotating vector objects or Sizing and
transforming text.
| To scale or transform a selection, layer, or image |
Edit workspace
1 |
Choose a selection, layer, or image by clicking its name on the
Layers palette.
2 |
On the Tools toolbar, choose the Pick tool |
A bounding box with handles appears. |
3 |
Perform one or more tasks from the following table.
By default, you must hold down Ctrl + Shift to distort an
image. To distort an image without holding down keys, choose
a different Mode setting on the Tool Options palette. The Scale
mode is the default setting, so you must hold down a key or
keys. The Shear mode lets you shear without holding down
Shift. The Perspective mode lets you change perspective
without holding down Ctrl. The Free mode lets you distort
without holding down Ctrl + Shift.
When the Pick tool is active, you can scale and transform
precisely by setting values in any of the boxes on the Tool
Options palette.
