Objects
Working with objects is an essential part of creating drawings.
This section contains the following topics:
• Select objects
• Edit objects in Focus mode
• Transform objects
• Copy, duplicate, and delete objects
• Create objects from enclosed areas
• Create a boundary around objects
• Feather object edges
• Use object coordinates to draw and modify objects
• Copy object properties, transformations, and effects
• Clone objects
• Position objects
• Align and distribute objects
• Apply object hinting
• Snap objects
• Dynamic guides
• Alignment guides
• Change the order of objects
• Size and scale objects
• Rotate and mirror objects
• Modify objects with the Properties inspector
• Group objects
• Combine objects
• Lock objects
• Find and replace objects
• Hide and show objects
• Constrain objects
• Export objects
