CorelDRAW lets you add lines by using a variety of techniques and tools. After you draw lines, you can format them. You can also format the outlines that surround objects.
CorelDRAW provides preset objects that you can spray along a line. You can also create flow and dimension lines in drawings.
This section contains the following topics:
You can draw lines by using shape recognition. For more information, see Use shape recognition.
You can also draw lines with precision by using object coordinates. For more information, see Use object coordinates to draw and modify objects.
