Work with bitmaps
You can convert a vector graphic to a bitmap. You can also import and crop bitmaps.
You can add perspective, shape bitmaps with envelopes, apply color masks, watermarks, and special effects, and change the color and tone of the images. For information about applying perspective to bitmaps, see Apply perspective. For information about shaping bitmaps with envelopes, see Shape objects by using envelopes. For information about applying effects to bitmaps, see Bitmap effects.
This section contains the following topics:
Convert vector graphics to bitmaps
Crop bitmaps
Bitmap dimensions and resolution
Straighten bitmaps
Correct perspective distortions
Remove artifacts and noise from JPEG images
Remove dust and scratch marks from bitmaps
Sharpen images
Change and mask colors in bitmaps
Image Adjustment Lab
Adjust color and tone
Tone Curve filter
Transform color and tone
Edit bitmaps with Corel PHOTO-PAINT
