Fills
You can add colored, patterned, textured, and other fills to the inside of objects. You can customize a fill and set it as a default, so that each object you draw has the same fill.
Fill samples
This section contains the following topics:
• Uniform fills
• Fountain fills
• Hatch fills
• Vector and bitmap pattern fills
• Two-color pattern fills
• Texture fills
• PostScript fills
• Mesh fills
• Apply fills to areas
• Work with fills
