You can insert page numbers on the current page, all pages, all odd pages, or all even pages. When you insert page numbers on multiple pages, a new master layer is automatically created, and the page number is placed on it. The master layer can be an all-page master layer, an odd-page master layer, or an even-page master layer. For more information about master layers, see Creating layers.
Page numbers are automatically updated when you add or delete pages in your document.
You can also insert a page number inside existing artistic or paragraph text. If the text is located on a local layer, the page number is inserted on the current page only. If the text is located on a master layer, the page number becomes part of the master layer and appears on all pages where the master layer is visible. For more information about artistic and paragraph text, see Adding and manipulating text.
If the page numbers are on a master layer, you can hide the page number on a specific page by hiding the master layer on that page.
You can change the default page number settings before or after you insert page numbers in your document. For example, you can start the page count at a specific number other than 1. This is particularly useful if you want to create multiple Corel DESIGNER files that will be put together as one publication.
You can also specify whether to start page numbering on the first page or on another page. For example, if you choose to start page numbering on page 3, page 3 displays the number 1. If you insert a new page between 1 and 2, it becomes the new page 2, whereas the old page 2 becomes page 3 — the page where the first page number is displayed.
You can also choose from a variety of commonly used page number styles.
When you save to an earlier version of Corel DESIGNER, page numbers are preserved as editable artistic text. However, if you add or delete a page, the page count will not be updated.
Page numbers are artistic text objects (unless you insert them in paragraph text) that can be modified and manipulated like any other artistic text object. For example, you can resize, scale, or rotate a page number, change its color, or apply effects such as texture fill or a drop shadow.
When the page number is on a master layer, applying transformations to it affects all page numbers.
The following table lists various ways to manipulate page numbers as objects.
| To insert a page number |
Click Layout |
On active layer — lets you insert a page number on the layer that is currently
selected in the Object manager docker. If the active layer is a master layer, page
numbers are inserted on all pages of the document where the master layer is
visible. If the active layer is a local layer, the page number is inserted on the
current page only.
On all pages — lets you insert page numbers on all pages. The page number is
inserted on a new all-page master layer.
On all odd pages — lets you insert page numbers on all odd pages. The page
number is inserted on a new odd-page master layer.
On all even pages — lets you insert page numbers on all even pages. The page
number is inserted on a new even-page master layer.
The page number is centered at the bottom of the page. |
In the Object manager docker, the page number appears as an artistic text
object with the name “Page number.”
You can insert page numbers on odd pages only if the current page is an odd
page, and you can insert page numbers on even pages only if the current page
is an even page.
You can move the page number anywhere on the page by selecting it with the
Pick tool and dragging it to a new location. If you move a page number outside
the drawing page, the page number turns into the generic number sign (#). If
you then place it on another page, it displays the correct number of the page.
You can also insert a page number inside an existing text object. Using the
Text tool, type artistic or paragraph text. With the cursor inside the text
object, click Layout |
| To hide the page number on a single page |
1. |
Select the page in the Object manager docker.
If the Object manager docker is not open, click Window |
2. |
Click the Layer manager view button
Only layers on the current page are displayed. Changes you make to the layer visibility in this view affect only the current page. |
3. |
Click the Show or hide icon
The application hides the page number of the current page, but the page is still included in the page count. All other pages continue to display their page numbers. |
| To modify page number settings |
1. |
Click Layout |
2. |
In the Page number settings dialog box, choose any of the following options.
Start at number — lets you start the page count at a specific number
Start on page — lets you specify the page on which to start page numbering
Style — lets you choose from commonly used page number styles
